I've used these in a motorhome conversion and have been very impressed.
As long as care is taken it's totally waterproof and can stand up to pretty rough treatment.
I did mine with Multipanel but, if I was doing it again I wouldn't rule out the 1m wide panels from wet Walls and Ceilings. It's 1m wide by 2.4 tall. It's light and easy to cut, totally waterproof and can take a good thump (I've tried to damage it).
Did this for a neighbour and they were well pleased with the result.
Wall panelling and bath panel matched the same. Ceiling done also with white pvc.
It puts a glean to surfaces that you just don't get with tiles imo.
First time I'd used the stuff.
It won't collect grime the same way that tiles do and a lot easier to clean.
It would be first choice for my own home. Each to their own.
