Bathroom dimmer switch and Extractor fan
9 Sep 2005
Ayrshire
Hello All,
I would like to know if it is possible to get a suitable dimmer switch or wiring set-up that will allow for the following. With both the lights and the extractor controlled with one switch.
Lights in bathroom on a dimmer switch and the extractor coming on when the lights are turned on. It would be even better if the fan only came on when the lights were at 100%.
I know that light dimmers and fans are not normally compatible because of the way light dimming works. But is there a way for this to happen without having to have 2 different switches?
Andrew
It would be possible but very expensive to have the fan come on when the lights hit a peak voltage through the dimmer switch.
A cheaper and more efficient way would be just to have a standard switch and timer fan.
RMS
How expensive and how? Not so bothered about it coming on at peak voltage, just would be an added nice touch. Would just like to able to dim the lights sometimes and have a fan come on with one switch.
I have just had a thought, it would only be occasional that we would want to dim the lights, could I put a dimmer switch between the pull cord and the lights. Therefore being able to have the fan and lights come on with one switch, but have the ability to dim the lights when desired?
Andrew
please note the forum rules
Something like this would be fine.
Hi RF, thanks for that, that should do the trick, just nicely.
Can I ask which rule I have broken, is it to do with replying to my own post? Don't want to get into trouble, how should I have gone about it?
Also, despite what my flag might say, I am in the UK, just picked Tanzania when I signed up cause I fancied it. Sorry if that has caused confusion.
Andrew
Think you may have answered your own question there
rule 9
Andrew
It does cause confusion. If I let you post in UK electrics with a non UK flag, I will have to let everyone do it. Before we had electrics out side of the UK there were quite a few confusing posts
You can change your flag in your profile
Where's Breezer these days?
Hi Securespark, I believe you :-) I had looked at that product, on tlc, but had not come accross the technical information, probably did not look properly.
The switch has 4 connections, I believe. I have contacted Dimpull for further info and will post it here so that you can have the info from the 'horse's mouth' so to speak.
The only potential problem is that it can only do 175W with low voltage, it would appear, despite quoting 250W as the maximum with mains lights.
I just wonder if it will work with a fan which does not have a timer on it, if the fan only has a switched live.
Andrew
