bathroom electrics
2 Apr 2008
London
hi gents hope you can help and advise
I want to remodel the bathroom totaly from scratch, at the moment there is a sperate toilet which im going to knock down the wall between which should give me a bathroom of aprox 8ft by 8ft
As you enter into the bathroom there is a small passage with a door to the left which goes to a huge airing cupboard about 6ft deep with an emersion tank. and straight ahead is the door to the bathroom area
what i would like to do is remove move the door to the bathroom and put it at the start of the passage. so the door doesnt open into bathroom area.
the airing cupboard would then be in the confines of the bathroom.
The plan is to install a new combi boiler in the airing cupboard and remove the water tank and cylinder.
Is the airing cupboard now considerd to be part of the bathroom?
and as such no electrics would be allowed in the airing cupboard?
If i install a whirlpool bath can the electrics for this be in the cupboard
Thanks in advance for any advise.
You seem to think that no electrics are allowed in bathrooms. I guess yours must be lit by candles, or gas lights.
You've basically got two choices.
1) Engage the services of a registered electrician to carry out the work.
2) Familiarise yourself with what the requirements actually are. A good way to start would be the following:
a) Read the Wiki article on DIY and the law, as the work is notifiable.
b) Get copies of the On-Site Guide and the Electrician's Guide to the Building Regulations.
Thanks for the really helpful reply - not
As this is a forum for asking questions, i thought it might be a good idea to ask one, on the hope i would get an intellegent response.
simple question, simple answer.
Thanks for pointing out that electrics are allowed in the bathroom, I always wondered what that pull switch was for.
nowhere in my post did i say i was going to engage in the work myself, all i was trying to do was gauge if what i want to do is feasible. i believe its called forward planning.
I am aware of the other website but i thought a reply on a forum of this nature would be a lot better than me trying to interpret a field that i am not qualified in.
one again thanks for the positive response you truly are a guiding light.
Perhaps you should have done us the courtesy of asking intelligent questions then...
OK - so that makes us even.
Now perhaps you could explain why, if you know that electrics are allowed in the bathroom you wrote:
"Is the airing cupboard now considerd to be part of the bathroom?
OK - I misinterpreted, I know you didn't explicitly say you were going to do the work yourself, but you didn't explicitly say otherwise, and you started out saying you were going to knock down the wall, you were going to move the door....
See above - if you were planning to do the work yourself then you would have needed to read the Wiki article and get those books.
