I want to have fitted a bathroom extractor fan, before I get the experts in I have been reading up on the regs and zones, and I have a few questions if I may.
This is a very small bathroom, its only as long as the bath. At the tap end there is a shower tap, and along the side of the bath there is a window.
Looking at the zoning diagram I downloaded from the internet, it seems that inside the bath is zone 0. All around the bath is zone 1 up to a height of 2250cm, and about half a metre from that is zone 2. Anything outside this area is considered a standard installation that must meet the relevant regulations as far as my fan is concerned - is my understanding correct ?
Now - the Fan I wish to have fitted is a 240v timed habistat. I have measured the distance from the floor to where I would like the fan mounted, and there is about 2300cm from the floor to the bottom of the fan case.
Positional wise, is this fan OK to be above zone1 ? - it will be directly above the bath but more than 2.25m vertical from the floor. If someone was to stand on the bath they could touch it though.
I know there needs to be a 30ma 3a spur fitted outside the bathroom, and a double pole pull switch.
If not then I guess its a low voltage fan for me.
