Bathroom fan light combination
10 Sep 2005
Staffordshire
I'm looking for a fan light combination on the ceiling within my shower enclosure. The ones I have seen so far either don't produce enough light or the fan doesn't seem to have enough oompfh to draw the steam out.
Can anyone recommend one that gives at least 100 watt light out put with a strong silent fan?
100w bulb will kick out some heat which will cause the glass to implode if water splashes on it. Most units only have a 12v transformer supply to the light so you may have to look at led options. The inline fan can be any size you like we use Manrose MF range which are powerful and can be made quiet with appropriate fixings to minimise the vibration transfer to the ceiling joists which is generally what makes it noisy.
Pete
Sorry I should have been more clear, I wanted the equivalent of 100W output of light that you would have got with the tungsten filament bulbs but use less watts on the actual device, if that makes sense.
