bathroom fan without timer
9 Dec 2013
Essex
I'm fitting a new extractor fan in my bathroom the old one was old and noisy
the bathroom has a fan isolator switch outside of the bathroom on the wall
the only problem I can see is my old one has a timer and my new one hasn't, there are 3 wires on my old one(red, yellow/green, blue) I'm guessing that the red is the live feed, the blue is the neutral and the yellow/green is something to do with the timer maybe a switched live?
so I think all I need to do is just connect up the permanent live(red) and the neutral and the fan should come on when the lights in the bathroom is turned on? and tape up the yellow/green wire
can someone confirm this please
Yellow and Green should only be used as a circuit protective conductor therefore it is connected to earth!
Red will be live and blue neutral(well that's what you would expect them to be).
Please be careful, if som idiot has used the cpc as a switched live !
KA
Red and Blue together says to me pre-harmonised 3C+E so maybe the G/Y is actually just Yellow?
That's a fair point, its possible that the green/yellow is yellow or possible that the yellow has been cut back.
I think a little more investigation is required by the OP!
Or as I found in my parents loft, yellow connected to the CPC at one end with the CPC cut back, and the other end, CPC connected and yellow cut back :twisted:
Pictures please OP
thanks for all the replys chaps
I've just had another look at the connector block that the wires go into on the old extractor fan and are labelled as follows
L = red
N = blue
SL = yellow
I thought the switch live was yellow/green but actually it's a plain yellow so everything should be straight forward to wire in now, I take it the switch live is not needed and all I need to do is tape it up and tuck it out the way?
Why did you purchase one without a timer? It maybe possible that you are now introducing a moisture/condensation issue into the bathroom.
You'd be wrong there. If your fan is a non-timer one then you need blue for neutral and yellow as the switched live. The red is a permanent live and you do not need that. Put the end in a bit of insulated terminal block (aka choc block) and tuck it out of the way inside the fan housing.
cheers thanks will do
