Hi All,
I am going to attempt to fit my new bathroom suite. The previous owners of the house had changed the layout of the bathroom and I am going to put it back to how it was, therefore I know that the water pipes, waste and soil pipes are all exactly where I want them. I have a few questions though if anyone can help:
1) Is there much difference or advantage to using compression fittings or soldering?
2) I currently have an electric shower and wish to fit a mixer shower ran off the combi. Is it ok to branch off the bath taps to feed the shower?
3) As the shower will be made of metal will I have to earth it? (same for all of the taps?)
4) I will need to remove a radiator to replace tiles. I assume I have no choice but to drain the system to do this but how do I go about doing this and then re-commisioning it. I have a Vokera Compact 24 combi.
5) I am wondering what to do if the height of the current soil pipe branch doen't match the height on the new toilet? Basically if its only a little off. Can you buy flexi connectors for this? Any advice?
6) When tiling the bath/basin is it best to fit the furniture and tile around or tile the wall and fit furniture to it?
7) Any advice on testing the integrity of the plumbing for leaks before fixing all of the suite into place?
8) Any general advice? I have read the how to guides but you can't beat experiance. I know this prompts the debate to get a plumber to do all this but due to cash flow it aint much of an option............ or is it? If this simply is a matter of connecting the suite as all pipes in correct location would it cost much (or is that too much of an open ended question?
Thanks for your help.
Mark
Mark
