Hi all - I have a problem with the LED spotlights in my bathroom, looking for some confirmation on likely cause before I go crawling into the tight loft space above (in case I don't have to!).
There are 4x LED spotlights in the bathroom, all 12v connected to a single driver. All 4 are flickering on/off in unison, and continue for flicker for around 10 seconds after the light switch is turned off. I've eliminated the switch as the cause, as there's a shower light and extractor working fine off the same switch (I switched the circuits around in the switch wiring just to check, and the same issue persists). I've also tried removing/replacing the individual bulbs and have tested them in other rooms, they're working fine.
I'm thinking the LED driver is the likely cause and happy to replace it myself - but is there any other likely/possible cause to check for first?
Thanks for any advice,
R
R
