Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi Guys,no it’s not tripping it only done that once. I didn’t use a junction box I will go up to the loft and trace it back,one thing I did notice was the T+E in the loft from the wall switch seems to be going away from the ceiling cable .
Sorry guys but I have a hospital appointment today and I have to go. I’ll check all that out when I get back I would appreciate it if you could stick with me about the wiring
it needs to go to a junction box to pick up the permanent Live to go down to the switch and then the switched live will need to return to the light somehow - along with a neutral from somewhere
hence the diagrams i linked to in my original post , which was the first reply in your duplicated post
you mentioned in first post
wired the mirror to a connector in a pattress box box behind it,with twin and earth going up to the ceiling rose through the loft,
Description and illustration of a looped ceiling rose
flameport.com
hopefully those images help show what SHOULD be going on for you
so the light switch will go to the Junction box and so will the cable from the light its self - it is possible there is somehting else going on in the loft
photos will help here
happy to stick with you - will get a notification when you reply
