Extra low pre assembled CE marked lighting sets in bathroom are they notifiable ![Eek! :eek: :eek:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Are we ever, ever, ever going to get rid of that invented "requirement"?If you are replacing like for like then notification is not needed.
Invented by the writer(s). The law does not say that.The guide to part p in reference to table 2 note b states like for like,
Your understanding is slightly flawed.And my understanding is that a replacement (like for like) is allowed within special locations, but any other installed hardwired equipment must be notified as legal requirement.
You need to let go of this "like-for-like" thing.
Just read Schedule 4.
Provided the existing circuit can cope with a higher current, i.e. you wouldn't have to change the cables or the MCB, you could have a more powerful shower - there's nothing in the regulations which says the replacement one has to be the same.I agree with Chris, you are allowed to change like for like.
I was refering to guidence note K
A replacement is a replacement.Thanks for the link pal. I have read it, now banging my hid against a solid object.Just read Schedule 4.
I know we have and maybe I should stop using the term like for like rather than replacement.No - I'm saying that it doesn't have to be like for like to be non-notifiable.
But we have been through all this before:
Am I wrong in thinking that you can not replace a LV for ELV without notification.A replacement is a replacement.
You can replace a light with any other type of light.
What does where?States that modular wiring systems installed in a bathroom or special location are NOT NOTIFIABLE
Yes, you are wrong, as long as the lighting is not a special installation, i.e. as long as it is a pre-assembled lighting set bearing the CE marking referred to in regulation 9 of the Electrical Equipment (Safety) Regulations 1994.Am I wrong in thinking that you can not replace a LV for ELV without notification.
So the lights you're planning to install use plug & socket connections throughout - on both LV and ELV sides?Look at EFLImpudense comment 3c
