Bathroom mirror and shaver socket
  • Thread starter Thread starter hi1
  • Start date Start date
hi1
4 May 2008
Gloucestershire
Sorry but the text Wiz robbed. Installed in fire in France rctm2t8 lights work shaver socket doesn't, 2 fitted any ideas by looking at photos what's wrong, thanks
Not really.
The picture of the switch and connections isn't clear enough - but I don't know if that would help.
Can you translate your original question?
Sorry visitors arrived, been fighting Bluetooth to get pictures off phone onto tablet to post. My query basically is I have two of these mirrors both with shaver sockets. Both lights work but neither socket. They may have been installed by a French sparky and this makes me wonder if the sockets are wired up from the transformer? correctly, red and blue wire in same hole. There are also two brown wires at the transformer, one either side both of which terminate in the same hole on the shaver socket? What I was hoping for was either wiring diagram for this model of mirror or a the brown wire from the transformer should go in the system or a hole to make it go explanation at my level.
I can't find any wiring diagrams.
When you say wires go in the same hole, I presume that they then go to different connections.
Can you take off the black cover?
It shouldn't have been necessary to alter any wiring other than connect the supply cable.
Can we have a clear picture of all the transformer connections?
Here is a simple diagram of a dual voltage shaver socket.
As your transformer and sockets are separate, Three wires needed for the two voltages.
I presume the other two wires are used for a switch to turn on the transformer when you insert the plug.
Indeed. How do you know the transformer does not work (indeed, if both don't work then you have a basic misunderstanding of something).
Look, I'm going to be in the Biarritz/Bordeaux area next week. Shall I drop in?
Thanks for the replies gents.
Good point that the mirrors should have been presided but I don't know if a French sparky has intervened because it didn't look right to him.
It's strange that both sockets don't work
have tried razor and tooth brush chargers in the sockets all of which show lights when used off a UK adapter for these devices
I will go back and remove black cover. the mirrors are in rooms with no natural lighting so with that circuit off its a bit dark for photos
once again thanks for your interest
currently located lower normandy
So is using a device which does not decide it knows in advance better than you what you want to write.
