Bathroom Mirror led sensor
30 Jul 2004
My bathroom mirror with sensor on the side does not work. I have replaced it with new driver and sensor but it does not work. There is power coming up to sensor and when you wave hand, you can hear click noise but led lights does not come on.
Can any one please help? Is it possible that led might have blown off.
Will it be possible to replace or connect sensor with on/off switch.
Many thanks.
Firstly, simply bypass the sensor and see if the lights work or not.
If the lights work then, for some reason the sensor must be faulty or not the right one.
Of course, an appropriate switch could be an option.
TTC,
Many thanks for your kind advise.
The led driver and sensor I am using is the same brand which is behind the mirror.
I have tested LED by passing sensor and it is working fine.
I think the sensor is defective.
Please can you kindly advise the switch I should use instead of sensor.
Your help is highly appreciated.
Thank you.
It isn’t easy as you are introducing a switch that will be connected to an unprotected mains supply in a bathroom.
A sensor switch is designed for this as you don’t touch anything to operate the light. A replacement sensor and its power supply is the best solution.
If you are going for a manual switch this would be the way to do it
