Bathroom panels over lining paper
25 Jan 2024
Hi , Promise this isn’t me that’s done this or am asking for a friend query lol
My mum has been decorating her small bathroom , so had told me her plan was to put new wallpaper up , I’ve now been informed she started the job by putting up
Lining paper , Then deciding to put up bathroom panels instead and has put a few up before telling me
Is that a no no and they will have to come down ? She has used adhesive and even drilled screws in the lips of the panels
She seem quite pleased with herself but im not sure it works
It's not ideal, but whether they need to come down depends mostly on where they are and how they're fixed.
The weak point is the adhesive. It only bonds to the lining paper, and the paper is only as strong as its paste to the wall, so if moisture gets behind it the paper can let go and take the adhesive with it. The screws through the tongues into the wall are what will actually hold the panels, which is good news. If they go into plugs or studs roughly every 300 to 400 mm along each panel, they're mechanically fixed regardless of the paper.
  • Away from the shower or bath (e.g. a feature wall), with screws like that, I'd leave them and finish properly: trims at the edges and silicone along the top and bottom so steam can't get behind.
  • In the shower area or right around the bath, I'd take those few down, strip the paper there and refit them. Water gets behind panels at joints and edges there eventually, and soggy paper behind them means mould and a smell later.
Since she's only done a few, now is the cheap time to decide. Panels usually come off fine if they're mainly held by screws.
