- Joined
- 2 Nov 2009
- Messages
- 631
- Reaction score
- 73
- Country
Hi guys,Fantastic forum - I have lurked as a guest for ages but now I would like some help please.
When we bought our house it had a shower enclosure, next to the bath. The (resin) tray had a crack in it and I have finally got around to changing it.
Hellsteeth what a job! - they built the bathroom around it so I have carefully dismantled the (daryl) shower door (will be re-used) and the stud walls and finally yesterday removed the old tray (dam heavy aint they!)
...found out why it cracked - it was only on a (very) wonky 12mm ply base (in 3 pieces!!!!)
So now the rebuilding can commence, but first some questions!
1/ I need a 1200 x 800 tray recommendations please - they seem to vary from £50 - to over £300 and I only want to do this once! (cost is not necessarily an issue old tray was 11cm deep can i use a lower profile - weight!)
2/ will 18mm ply be sturdy enough as a base?
3/ Are all thermostatic mixer units a standard pipe layout (fittings in/out)
4/ I intend to use aquapanel /tile in the shower but for the rest of the bathroom (currently panelled) will 12mm ply be ok?
5/ is there such a thing as a flexible waste fitting? - the waste pipe is under the bath and alignment may be an issue (I am NOT taking the bathy out if I can help it!)
6/ can someone confirm that sand/cement is the best bedding material? - I suppose my choice of tray will answer this???
7/ finally back to the platform - existing one runs on top of old floorboards but paralell to joists should i rebuild on a sheet of ply first or is this acceptable (may as well change it if advised)
phew what a post! sorry about all the questions and thank you in advance for your help
