Just got the keys to my new house and really want to replace the bathroom before i move in in 2 weeks time. By replace i mean everything, its all pink (including some pink mirror tiles
). The layout is ok so the list of things i need to replace is:
1) Carpet with vinyl tiles
2) Tiles and vinyl wallpaper with non-pink tiles and vinyl wallpaper
3) bath, toilet and sink
I've got a diy book which tells me how to install most things, and i found an order to do things elsewhere on this forum , but there are a couple of htings that i'm a bit nervous of. The first is theres an electric shower above the bath in the vinyl wallpaper section and i'm wondering if i'm going to need to remove/tamper with that shower when i do the wallpapering or is there some easy way around this? The second is that the diy book suggests that if removing the basin is difficult i should just cut through the pipes, this seems a bit drastic to me and i was also wondering if you can still cap pipes if you cut through them?
Cheers for any info you can provide and any helpful tips on the process would be appreciated.
