I have a bathroom with the following equipment:
Shower (zone 1) with a pull cord switch (zone 3)
Class II extractor Fan (zone 2) with a pull cord switch (zone 3)
Pendant lamp and a pull cord switch (both outside of the zones)
Shaver unit (zone 3)
The bath, sink and radiator pipes are copper and the waste pipes are plastic.
The shower water supply is in a stud wall, does that need to be bonded?
Can I bond to the CPC of the shower switch and extractor fan switch instead of the actual shower and fan?
As the fan is double insulated and there is no CPC in it, how should it be bonded?
Do I need to bond the hot and cold sink pipes together as well as the hot and cold bath pipes together, even though they are only a few metres apart and are all joined together by copper pipes and soldered joints?
Do I need to bond both radiator pipes?
Can I ignore the light and switch as they are outside of the zones?
Any help will be much appreciated.
