batten lights wireing
25 Sep 2021
uFNjhLdLudZ2fn_W-KHq-OjE8SJW9ke_VcQBo9WNBpoBiTmvheWbg7QROWOWliZmHqrgBFVyDvcrJUo-affYfmCwdZDsFucaDoU9B5jDywwCH1xjTT_mfbXht_lf3l6fV5UdKWuirnEIL883WtufDjBaiuqVUBbEnlCKXmFSosj64UD8NAo2JBpJfDYnbrGMerYJvOBlZtzBN6brWHffr1qMxc7XyFceGrPR5iUbf8AVGW_oKRSaUxvF3Q9z7gwG5YUshKYUmwfAnzxmXWu0aIbEMg9zhyC3mAsigGrz3cP7GOnN3TJiMMqEBdTz9Xmxi7MIWPmyotCBEs6FW7faV2wDj47a4Huz4GgldRtD0FwpF0bXXXsTEUrGwo9pqoFtJYyMoPsUW5cxqc1HyLmUzSWBm80aBl6lAwTlkgihI5IDEiYEriDId7XGt_sKRRil7DP_CWmfRBJWRoNg3MrbFuZNr-x9FpivUD0b4VN3j9f5gwGM-MvyuHa3L8HyIbt-Ebb3yNKvUqYhJ8nQSjdIsWYOHKEJryBmS0tSZunjvMu0HRFYU2ekCvB5rY35L9lcx714JUqBJQeIheOiM4eOSUi9ZNuKC2Z_kdqbQ2gM2DkfLYP9TJtEhyYV7TRx5U33ybfWVxFnbPmphWM3I2asAlJ1IYbptwFAktvOGfGJ7uBbTS_Bnku0AAQ9MOL5459KF7QTk5K6WhSR0fDS2QmDNqE=w278-h617-no
putting a plug on a batten light when I came to wire it up there was white wires not sure what to do the brown wire you see is just pushed in need help thanks
A cable tie or similar to act as strain relief on that cable may also be a good idea.
The centre earth terminal should be fixed to the metal tab below it, the screw is also missing.
You will need a replacement terminal block to connect the earth wire.
