- Joined
- 27 Jan 2008
- Messages
- 29,949
- Reaction score
- 3,731
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
My father-in-law got himself a new Fujifilm Finepix S2900 Camera. On the instructions it says you must not use Ni-Cd rechargeable, only new Ni-MH should be used.
It also says don't use manganese batteries. There is a selector for Lithium, Alkaline, or Ni-MH which I assume is so it can give one an indication as to life remaining.
But I am confused as to why the two types are not permitted and as to how to work out what not to use?
Alkaline batteries I though were manganese Zn/MnO2, there is also Lithium Manganese Dioxide batteries often 3v per cell rather than 1.3 - 1.5 volt. There is also Lithium-Ion and Lithium-Ion-Polymer which I would think the camera which uses AA cells refers to when Lithium is selected.
I realise there are now many types of batteries i.e.
Primary Batteries:- Carbon Zinc, Zinc Chloride, Alkaline Batteries (Standard Alkalines or Premium Alkalines), Lithium Manganese, Zinc Air, Silver Oxide, Mercuric Oxide.
Secondary Batteries:- Nickel Cadmium, Nickel Metal-Hydride, Lithium Ion,
Lithium Ion Polymer, Lead Acid.
To name just some. Clearly in AA format you will not get Lead Acid but there are some odd ones like I have a RAYOVAC rechargeable Alkaline AA cell 1.5v not 1.3v as most rechargeable with a warning to use special charger written so small I need to wear two pairs of glasses to read it.
If I can understand why some batteries are not permitted then it will make it easier to select the right type. I do remember with early cameras the flash gun shorted out the battery for a few seconds and using Ni-Cd batteries allowed too much current to run. However the Ni-MH will allow more current than the Ni-Cd so that's not likely to be the reason why in this case.
So any thoughts as to why manganese and Ni-Cd batteries should not be used. The camera does not charge the batteries.
