A modern car with ecu, radio memory, alar, etc will flatten a battery in 2 to 3 weeks, if left standing, due to the constant drain although it is only milli amps. Friend of mine in the 80’s had an ameter fitted and drove 20 miles to work each way. By the time he got to work the alternator had just replaced the charge from starting the car for his journey. To top it up he had to drive further. At this time of year with the headlights and wipers on, heated screens etc it will take even longer.
Yes, modern cars, with modern electronics, rely upon being used regularly to keep the battery topped up against the constant drain of maintaining the elecBatronics. Two or three weeks parked is probably the safe limit for being stood without being used, because of the drain. If their is an issue with excessive drain, it can be awfully difficult to actually measure and even more difficult to track down - because there is such a wide difference between the maximum current and the possible drain when measured at the battery - a few hundred amps, versus drains of a few milliamps.
I spent a week on and off, working on my car, trying to track down a drain of 100mA, which pulsed rapidly and regularly on and off. I was lucky that my car has a removable bus-bar, which only fed everything but the starter motor's heavy current, so I was able to connect a meter across the bus-bar and remove it, to get a discharge measurement. Every time a fuse was pulled, it would wake up the car's electronics, so wait several minutes for it to 'sleep' again and maybe a hundred circuits to be checked by pulling fuses. Eventually, I pulled the one fuse which was the 'always on' circuit for the towing system and the drain dropped to a much more slowly pulsing 20mA. It was the voltage sensing relay, for fridge and leisure battery charging, just set to engage at just a touch too low a voltage. It engaged, which pulled the battery voltage down a touch, so it disengaged, battery voltage rose again, it re-engaged - rinse and repeat, until it had flattened the battery.
Back to the OP's problem....
11.7v = 10%; 11.8v = 20%; 12.2v = 30%; 12.3v = 40%; 12.3v = 40%; 12.35v = 50%; 12.4v = 60%; 12.5v = 70%; 12.55v = 80%; 12.57v = 90%; 12.6v = 100%
These are the battery at rest voltages, battery not under charge for at least 1 hour and with no loads applied to a standard lead acid battery, rather than an EFB battery.
