Hi all,
Over the past week I have noticed that the pressure gauge on my boiler shows 0 bars both on and off. When I turn on the boiler and hot tap the 60 light flashes after a short while indicating 'fault on pump or low pressure'. But if I leave it for a while then switch the dial over from 'heating and water' to just 'water' (and vice versa) it sometimes works and I can get hot water out the tap. I phoned up a number earlier for boiler maintenance and they said you have to turn one of the valves under the boiler. I looked under the boiler and I can see five valves but which one do I move?
Here is a pic (click to enlarge). I have numbered and circled each valve.
Thanks,
Mark
Thanks,
Mark
