Hi, please can some one give me an indication of what presure should be in the E/Vessel when the boiler is cold ? i see some people say 1bar, some say 0.5 bar, i just changed the Pressure relief valve as i was losing a little water through the pipe, i checked the P/Vessel and it had 0.5 bar in it no water came out when i pressed the valve so i assume the vessel is still ok. Pressure on the gauge of the boiler shows 2 bar when hot, drops a little to 1.7 ish when hot tap is on then back up when turned off, does this sound about right ?????
cheers
SIe
cheers
SIe
