Hi there.
I have the following problem with my Baxi 105e combi instant boiler:
With both DHW and CH, burner flame ignites (neon light comes on) but then after 3-5 seconds there is a clicking noise and flame extinguishes itself (neon light goes out). After about a second burner flame ignites again (neon light comes on) and sequence is repeated. There are no error lights on the boiler illuminated.
Pre-heated DW eventually reaches 80 degrees and boiler switches off, but we are unable to have showers or CH as water does not heat up quickly enough.
For info, I drained the system down to add some inhibitor and boiler has not worked properly since. All rads have been bled, system pressure is correct and I have bled the pump. I have also drained and refilled the system again but fault still occurs.
I have been advised that it might be an airlock in the boiler. If so, how do I clear this or does anybody have any other ideas as to what problem could be?
Any advice would be gratefully appreciated.
Rimmer 15
Rimmer 15
