Baxi 105e boiler
19 Sep 2009
Renfrewshire
Have been working on the flat today and had to switch off some of the valves to see which one was ofr the hot water but I cant for the life of me remember what postion they should all be
And before someone says open I mean
each one left/right or up/down
Just a bit concerned as the pressure now seems a bit high havent actually added/taken anything onto the DWS however I've noticed that the radiator in the kitchen isn't working
Any ideas?
If you are talking about the lever valves under the boiler then they should be in line with the pipework. Ie plastic lever vertical =valve open. Plastic lever horizontal= valve shut
I'm struggling with your last sentence, perhaps you could rephrase it to give greater clarity?
