Anyone checked the air flow side ie air pressure switch etc or supply polarity.
Work you way back through the sequence to see whats working at what isn't.
Surely the gas valve can be tested by seeing if the voltage remains constant?
Does the signal from APS remain constant? Same goes for flow switches? etc etc.
jeffc1970
I SAID SIMPLE.
DO NOT ARGUE
CHANGE THE LEADS
NEVER MIND YOUR CONTINUITY TEST
TOMORROW MORNING CHANGE THE LEADS
MUST BE BAXI GENUINE PARTS.
OTHER LEADS MAY NOT WORK
David.
yes I am shouting.
jeffc1970
Sorry about your deafness I will not shout so loud next time.
be very careful with the leads on the other boiler
They are not your average bit of copper wire with a pushfit connector crimped on either end.
I think you might find they are strands of cotton??? covered with carbon. Flex an old one too much and you may find you have to buy two sets of leads,
not to mention a few pints and a bunch of flowers as you have disabled your friends boiler for the week end![]()
David
What has happened or been done to the boiler since it last worked, presuming it has worked on LPG previously.
why didnt you just do what i did told the customer to get baxi out on a fixed payment think it was £300 pound they fix it no matter what and guarantee for a year
obviously not all the "components in it are 100% checked and working" or the boiler would work!!!
