Hi
All I wonder if you can help me- I had a plumber in to move my Baxi instant two foot,which was done a week ago, it now seems to have developed a problem but the fitter is now off work and is likely to be off for some time due to an accident.
I was hoping this may be something I could rectify in the meantime without having to pay for it again.
Following the units relocation it started cutting out the day after indicating with the first flashing led it cut out more and more until it wouldn't stay on at all.
I looked at it too see if anything was obvious and noticed a lot of dust on the burner, I removed the panels and vacumed all the parts put the panels back on inadvertently tested it the viewing glass off, everything seemed to be fine so I switched off and put it completely back together thinking I had cured the problem, however when I restarted it the same thing happened, realising this is something that is affected when the unit if fully rebuilt, I tested it by first taking the front panel off and tested (as expected) no change- so I removed the viewing window and found the unit ran but the flames were noisy, also I could hear air being drawn through the window, as suspected the burner died when it was replaced.
My assessment is that the unit is being starved of Oxygen, I confirmed this by replacing the glass and loosening the collar on the flue liner, this lets air in and also allows the boiler to run correctly.
When the unit cuts out the first led light flashes showing flame failure- it doesnt indicate a blocked flue - but if the liner was blocked I suspect the unit wouldn't detect this. of course we cannot run this now so its kettles for hot water- but in the meantime could someone please advise if this seems to be the right direction- could the liner be blocked somehow.
Dave
Dave
