Baxi 105e instant keeps Running
25 Jan 2009
Lancashire
Hi, I hope someone can help.
I have a Baxi Combi Boiler, it was fitted a while ago and runs with a 24 hrs Clock built in. The water temp and rad temp is set on the panel. I have 12 rads all 11 with TRV's. My problem is that the Baxi seems to run constantly when on even at lower temps as per the dial, which does work because if I turn it anti-clockwise it goes off but only for a Min or so then kicks back up. I do have some of the TRV's shut when not in use but still the same. Do I need it looking at or is it purely the size of my system. Or do I need a Room thermostat, if so which one and where should I locate it,
Any advice would be much appreciated
Marko
