Baxi 105e low pressure/pump fault warning light.
would rather spend my days doing CP12s then tackling divertor valves unless they are causing problems
so your 1hour 105 service includes taking out the whole divertor valve,stripping and servicing it,refitting checking then doing all the other checks?most 105s i work on have only had diapgragm kits in over 10years..seems grossly OTT what you do.
So you do service peoples boilers then??
indeed I do service boilers.Are you going to tell me I should be stripping the divertor valve for every boiler with one for every service?
what one person does for a service is up to them but if he is going to do that service and fix his problem at the same time what is wrong with that ;)
did i say that :rolleyes:;)
are you qualified to service these boilers your doing ?
if so, why not join the cc as you may learn a little ;)
my qualifications or lack of have sweet FA to do with you..the OP reckons he strips down the divertor valve on every routine service whether its faulty or not.Thanks for the tip on cc ..oh wise one
beg your pardon..correct .The OP never mentioned stripping divertor valves in routine servicing.My mistake.it happens.nothing to do with struggling with basics!
