Baxi 105e Remote Expansion vessel adding.
Depressurise the system by draining and gauge on 0 then I pumped vessel to around 0.8 bar .
The most important part is you MUST leave a drain point open as you pressurise the vessel, you will get a fair bit more water as you pump it up as you are now forcing the water from the vessel, when the water stops coming out then you will no be pressurising the vessel, take to 0.8 Bar then close the drain point and remove the pump
Did you drain the system from the boiler drain plug and isolate the radiators (the 2 outside pipes I think )
Should I turn the radiator taps off under the boiler ? I don't want to lose the inhibator
I really do appreciate your help but won't all the water from the radiators empty out ?
No it wont and if you close the isolationg valves they will most likely leak when you open them again, the water in the radiators will be held in a vaccum
Yes it seems to have worked fingers crossed. I obviously lost some water with inhibitor in it .
you will have lost a lot more inhibitor by constantly topping up the pressure when you had a depleted vessel
Just a quick question boiler guys , my boiler is working great now 1 bar cold 1.7 bar hot . What would have happened if I had put too much pressure in the expansion vessel ?
