Baxi 105e ,that may have a problem or may not ?
8 Apr 2008
Tyne and Wear
Hi everyone
I have tried looking for an answer to my question on here but I cannot seem to come across one so please forgive me if this has already been answered somewhere.
Okay I have a baxi 105e and i have the central heating turned off and I mean off by means of the switch on the timer but when I have a shower (which runs of the boiler) or I fill the bath with hot water the radiators get hot I am not sure if this is a normal occurrence or not its just I have never noticed it happening before any advice would be greatly appreciated
thanks
freeze
could be your diverter valve is letting by i.e when hot water being used the diverter valve lets by to rads instead of shutting off. usually you notice a change in the water temp. If it is the diverter it will need changing, needs a skilled rgi rather than diy.
ah cheers for the answer and like my fellow poster before you thank you for the quick reply ,do you know a rough price of getting one changed by an engineer ?
the 105e is one of the easy ones and yes a diyer can do it.
don't need a skilled rgi to change a diverter valve. ffs
as your working on a part of a gas boiler, even if its a water part its still in the boiler, you should do a burner pressure or gas rate don't think thats in the realms of diy do you
cheers for that mate do you know where I can find a drawing of it or something because I a vavle before and a diagphram when the hot water wasnt cutting in and thats been okay since I done it so I would like to have a look at doing myself if possible ?
thanks again
I see what your saying Ill try to price one up and get someone to fit it if necessary
thanks again you guys are great
what a sad jobsworth nomark. :roll: its hardly rocket science ffs.
how would changing a divertor or just simply the diaphragm on a 105e. involve gas rating or burner pressures.
Is the diverter valve the valve I changed the diaphram on last year to get my hot water working again ? or is it different I have looked on here and online and thery are so many different photos all named as the diverter valve
cheers
you should know,
what he told me.
even though it carries water its still in the boiler. what a silly f u k e r
