I have a 2-3 year old Baxi 105e combi boiler running central heating and heating the water. For a couple of months now, I've noticed that my bathroom shower is not maintaining an even temperature, alternating between running hot and cold every 20 - 30 secs or so.
Separately, I've also noticed that, when I turn on the hot tap in the bathroom sink, with a moderate flow, from cold, the flow reduces to a trickle as the boiler seems to start up. If I increase the flow a little, it reduces itself again, and eventually comes out slowly but very hot. When I open the tap more fully, everything seems to settle down to normal temperatures.
My heating engineer took a cursory look last week and suggested a new thermostat in the Mira Excel shower would cure that part and that the tap issue was nothing to worry about. So I fitted a new thermostat cartridge in the Mira yesterday (£90 ish) and it hasn't made the slightest difference...! I'm now concerned that the rest of the "nothing to worry about" advice may have been dodgy... and I still need to sort out the shower temperature proble.
I'm in Cheltenham - aparently hard water..? Could it be that the problems are caused by the 105e furring up somewhere or maybe a thermostat or pump or some other flow problem within it? I changed the diaphragm about a year ago and it worked fine after that. The fitting doesn't appear to be leaking. Grateful for any other thoughts or advice.
regards,
Andrew
regards,
Andrew
