Baxi (2) Solo 50PF
baxpoti said:
This is caused by the relay opening and shutting rapidly (chattering) due to a low voltage supply from the diverter, to solve the problem, you need a suppresor fitted across the boiler neutral and switched live.
Rubbish!
I suppose they are available (much like the new Suprima Board) at an inflated price by you money making ********'s
You lot apall me - charge a tenner in phone cals to inform me the PCB is fine, and low and behold....we know the rest.
Raden has the knowledge to challege you and you dismiss him.
David
Soggy_weetabix said:
Rubbish!
David
What's rubbish?
Most electrical wholesalers (if you mean suppressors)
I've never charged anyone a tenner for phone calls
When have I dismissed Radens knowledge
What I have done is try to answer the original question
Have you read the Honeywell wiring guide?
Nice bit on diverters and low voltages caused by back feed!
Does Raden know of this?
and how do you explain the last post before mine?
"Does Raden know of this? "
Raden wrote the beginners guide to actuators in the uk.d-i-y FAQs
load of crap mind ...
Fitted a honeywell valve and now all O.K.
It was the old type ACL valve without the removable head.
How do YOU explain that then soggy weetabix.
baxpoti...keep up the good work fella.
Very useful info for the DIY'ers who come here for help.
Hi, For those whohave suggested a solution Thanks.
I have measured the switched live voltage whilst the relay is chattering and it is about 180v, this is when the 3 way valve is moving over to the CH position.
I had previously changed the 3 way ACL drayton valve thinking this may have been the problem (after changing the PCB!), but did not resolve the issue.
Interested that changing the ACL drayton valve for a honeywell appeared to cure the problem elsewhere - Is the valve a straight swap & electrical wire connections & colours the same?
Do you mean you changed an ACL for an ACL ?
I change an ACL for another ACL (up dated model with removable head).
The question is - is a honeywell a straight swap in terms of dimensions to fit existing pipework & are elec connections & wire colours the same - Lastly will this cure the problem?
To the slaughter once more
These parts should be available from HRPC/or similar
TV suppressor 232111POT
Wiring Assembly - TV Suppressor 402A029
TV Suppressor Assembly 308A205
They should only cost a few quid tops
By far the cheaper option
Thanks - I'll get one and try it - At least its a positive step forward!
