Hello everyone, merry Christmas
We have a Baxi 80e combi boiler but have had no hot water for the last few days. The central heating is working fine and occasionally the DHW will work if the CH is on at the same time - but most times the DHW just doesn't get heated at all, regardless of whether the CH is on or off.
Sometimes the DHW will kick in if I mess about with the Reset/CH&DHW/OFF/DHW knob on the front of the boiler while a hot tap is running, but even if I get it working like this it fails to work again the next time I turn on a hot tap.
I read in another thread on here that there's also a reset switch inside the boiler but I can't seem to locate it. (I could take a photo if it helps)
All the LEDs on the front panel behave normally and no errors are reported. The LED for DHW illuminates correctly on the rare occasion the boiler sees fit to heat some water for us.
Any help diagnosing the fault would be much appreciated.
