Baxi 80e pump light flashing
27 Nov 2016
I am looking for a bit advice.
I have a baci 80e boiler and have had a few problems lately.
I have had a plumber out a couple of times.
Once when it wasnt firing up, pcb changed.
Then it was losing pressure, recharged expansion vessel.
Now when calling for hot water the pump light flashes. Water not getting hot.
Pin is coming out of diverter valve and making with switch switch clicks. Light switches from heating to water then the pump light flashes. Does same if heating is off.
There is evidence of water leaking through the pin.
Heating side is fine !
Any advice on what the fault could be please !!
Is this the pin on the top of the diverter valve ? the one at the front facing you comes out when calling for water and the one at the top comes up for heating
Yes top at the rear does it come up ? And also does it I back down when pump stops ?
It comes up and down for the heating on and off doesnt move for water but the one facing you comes out for water
finding it hard to follow your op ,
so your saying the ch pin works and the hw pin stays out and not retracting ? instead of saying water , say hw or ch ( hot water or central heating ). if pin is staying out with pump light fault showing . its probably shyte on the pin ,strip and clean it and change the o ring or seal around the pin to stop the leaking . may need a diaphragm ( depending )
edit ; if the pin is coming out and not switching it could be the microswitch being open circuit - new micro switch needed
Both pins are moving in and out !
I assume the pin on top at rear is the ch pin, this comes out and the heating comes on and goes in and it goes off all fine. i also assume the pin facing me is the hw pin, this comes out, the switch clicks and the light on the front panel switches to the water symbol (tap) but then the pump fault light comes on
are you getting tap light ( demand light ) coming on with hot tap on & pump running
edit ,tap on fascia
Have you tried resetting ? Does temp lights go out or straight to pump light flashing ?
