- Joined
- 27 Oct 2023
- Messages
- 8
- Reaction score
- 3
- Country
could you try answering this for me please.
i have new boiler and room thermostat , ive seen on someposts that it is usual that .when you set room thermostat say to 20° it is correct for boiler to ignite even at 20° as a smaller drop than 0.5 degrees is registered and boiler is maintaining rooms at 20°..even though room stat is not showing 19.5° which is when I expected boiler to kick in. could you just clarify this is still correct kicking in at 20°.
then this is the query..what happens..is this...so room thermostat set to 20°, boiler ignites whilst room tempeeature is showing 20°, flame symbol showing on both room thermistat and programmer.
so, ignites , runs for literally 30 seconds ,flame symbol goes off on both programmer and thermostat, i hear a click, then something continues running for 3 mins exactly and goes off.this repeats again exactly same every 3 to 4 mins later ..ignites runs for 30 secs, clicks off , something running 3 mins then off (fan or pump?)is this normal to run for just 30 secs and repeat over and over.
if I turn up the room thermostat manually from say 18 to 22 boiler ignites and runs as long as needs to reach 22° then clicks off but then does same thing as described ..ignites runs 30 seconds , 3 minutes fan or pump runs goes off..and repeats 3 to 4 mins later is this normal
please help advise
had several engineers out plus a basic warranty engineer from Baxi who said doesn't get involved with the room thermostat so did nothing ..other engineers hardly know how to set up the particular thermostat so am stuck..
please help advise
