- Joined
- 21 Jan 2007
- Messages
- 5
- Reaction score
- 0
- Country
I am at the end of my tether with this boiler. We moved in the new house 6 months back and it came with a gas fire in the front room with a boiler behind it. We have had nothing but problems with it since then. First off...
The timer switch was not working properly so we replaced it. The problem with the old one was the buttons where not doing anything, but now we have the new one we have to have water and heating runing together. Switch the heating off and just have hot water running and the rads heat up any how! this is a problem in the summer months when you dont need heating on!!!! could this be caused by the fact there is no thermostat on the wall?? if this is the problem how easy is it to fit one?
But since all this we have hit bigger problems.
Now the heating will fire up and warm the house up or at times it won't even get that far. It starts up runs some times for as little at ten minutes and then you hear the shut off thingy in side go click and it goes off. other times it will run for 2 days fine going on and off by the timer till it gets fed up and stops again.
I dont have a singel clue what it is or why it could be doing it, I dont pretend to be a plumber and have as much knowledge of a boiler as i do a human brain.
Many thanks
Steve
Many thanks
Steve
