Hi all,
Just had the boiler (Baxi Bermuda 401) on for central heating and my girlfriend sitting in the living rooms says it made two small popping noises after it'd been around 10 minutes. The boiler appears to be operating normally, ie blue flame, pilot lit as normal and cycling itself on and off according to demand from the radiators, any thoughts on what might have made it pop? It hasn't made any noises since or any that I've noticed before so I don't know if these may hae just been expansion as the boiler has been off all day and it's been quite cold up here.
EDIT: Also, it has been quite windy today in case that's causing a vacuum in the chimney? Looking under the boiler there's a little bit of dirt but not very much and I don't know if this is anything to do with the popping - we've had it on again and, so far, it hasn't made any more odd noises.
Thank you! David
Thank you! David
