baxi boiler
13 Nov 2011
Tyne and Wear
switch on central heating boiler fires up straight away click it on to hot water and not a flicker of a flame any idea's what is wrong can it be fixed and will it be costly
More info is required
make and model of boiler, is it a combi etc. :)
I Would Suggest Dhw Diaphragm Part No 5111137 it sounds like you have a 80 or 105 baxi With a Split Diaphragm,Turn on Hw Tap Look At Boiler Do You See A Green Light Indicating Water Demand If Not 100% Diaphragm
Combicare,
Your crystal ball must be working better than mine tonight,
I prefer to know what boiler we are working with before I give advice.
David.
it's a baxi combi boiler 105e ignites for central heating when you switch it on to hot water only no ignition at all green light comes on to indicate it's turned on hot water but that is it
