Hi
I've got a Baxi Combi 105e and about 2 months ago was getting the hot water issue, the how water got warm, then cold, then warm etc.
Eventually the water would not get hot at all. The hot water light on the boiler came on when the taps were turned on, the boiler would then try to ignite but fail & one of the LEDs would flash.
So I cleaned the heat exchanger (the one at the bottom of the boiler, not sure if this is the primary or secondary?) which resolved the problem.
A couple of week back this started all over again so last weekend I cleaned it again and there was hardly any scum. The hot water worked ok in the week.
Today, no hot water. The boiler tries to ignite, fails, led flashes.
The central heating is fine.
Do I need a new heat exchanger or is there anything else I can check first?
Adam
Adam
