re the previous post,
the boiler came on as per timer,led light showing heating,temperature led lights came on all the way up to 80 degrees (quite quickly) burner light goes out, I can only assume the pump doesn't kick in, I turn the hot water tap on, domestic hot water led is on. hot water flows,turn tap off C H led comes back on temperature leds go back up to 80 degrees boiler goes off again no flow to rads,you can repeat the same thing 15 minutes later and then the boiler works as normal and supplies hot water to the rads.I would say the pump is ok, have I got a diverter problem or is it something simple , any ideas. thanks
