    Dismiss Notice
Baxi combi 105e - hot water problem - seems to 'run on'
Discussion in 'Plumbing and Central Heating' started by Steve1971mint, 26 Oct 2011.
  1. Steve1971mint
    Steve1971mint
    26 Oct 2011
    2
    Thanks Received:
    Nottinghamshire
    Country:
    Hi, firstly apologies but I have searched the forums but don't seem to be able to find an answer to my problem.
    I have a baxi combi 105e which works fine except for after running hot water the boiler seems to 'run on' in hot water mode for upto 2 minutes.
    What happens is when hot water is called for all is fine, the boiler switches from ch to hot water if ch is on and the boiler will ignite (if not already ignited while running the ch) and hot water runs.
    The problem is after turning the tap off, the boiler flame will go out almost straight away (which is normal I think if the ch is off) but the tap light will start to flash on the boiler, this continues until all the temperature leds are lit right upto 80 degrees. At this point the tap led will stop flashing and the lights start going off in sequence until right down to the last one. During this period of the lights going on and then off if the ch had been on before calling for the hot water the boiler will not switch back to ch until the lights have gone through this sequence.
    After this if the ch is on the boiler will reignite and the ch light will light up again.
    Any advice would be greatly appreciated
  2. Sponsored Links
  3. ROSSGR
    ROSSGR
    27 Apr 2009
    75
    Thanks Received:
    8
    Glasgow
    Country:
    It's the hot water preheat. SO yob get water quicker when you do open the hot tap. I think it you tuen the hot water stat down on the boiler you can turn it off. Have a look.....sure it says preheat
  4. Steve1971mint
    Steve1971mint
    26 Oct 2011
    2
    Thanks Received:
    Nottinghamshire
    Country:
    Well do I feel silly now - lol
    Yep it does exactly as you suggest, the only difference is that if you turn the preheat to off the hot water is a little cooler when up to temperature than when the preheat is on.
    Many thanks for your speedy response
    Steve
  5. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
