Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Hi, this baxi 80 eco does not start at all in both hw & ch the only part running is the pump, Hi Limit stat ok no 240v at the fan, checked all the cables for continuity ok, pcb!!
by limit stat you mean over heat stat on left hand side have you bridged it out. As dave said make sure microswitch on TOP of divertor is being activated
