    Dismiss Notice
Baxi eco 80 flame fault
Discussion in 'Plumbing and Central Heating' started by Eddieglmr8105, 13 Nov 2018.
  1. Eddieglmr8105
    Eddieglmr8105
    13 Nov 2018
    6
    Thanks Received:
    Country:
    Hi my baxi eco 80 fires up runs for a few seconds and stops with the flame fault code. I have just changed the pump and housing as they were leaking and all was well before that any ideas?
  2. Sponsored Links
  3. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    What is is the fault code being identified?
  4. Eddieglmr8105
    Eddieglmr8105
    13 Nov 2018
    6
    Thanks Received:
    Country:
    The flame fault red led lights up.
  5. Eddieglmr8105
    Eddieglmr8105
    13 Nov 2018
    6
    Thanks Received:
    Country:
    Does that make sense?
  6. PrenticeBoyofDerry
    PrenticeBoyofDerry
    30 Jun 2009
    21,628
    Thanks Received:
    2,383
    Londonderry
    Country:
    A flame fault code is very vague and could be down to any one of a number of issues, the cheapest first fix would be the the ignition electrode but there is no guarantee that it is this. You will need GS registered engineer to do this, so is it worth calling one first for a visit, often best for someone to see first hand what is going on.
  7. Sponsored Links
  8. Eddieglmr8105
    Eddieglmr8105
    13 Nov 2018
    6
    Thanks Received:
    Country:
    Thanks the boiler does fire up I can see the flames inside and it goes for probably 5 to 10 seconds of burning then it shuts down with the red warning light but the pump keeps running.
  9. ianmcd
    ianmcd
    15 Aug 2010
    15,604
    Thanks Received:
    5,582
    Lanarkshire
    Country:
    did you disconnect the electrical supply when working on the pump ? reversed polarity on the incoming supply will give the exact fault that you describe
  10. Eddieglmr8105
    Eddieglmr8105
    13 Nov 2018
    6
    Thanks Received:
    Country:
    Thanks I will check
  11. Gasguru
    Gasguru
    9 Sep 2005
    11,011
    Thanks Received:
    2,777
    Sussex
    Country:
    Check the white glass fibre coated cable on the RHS of the chamber is still connected to the main pcb.
    • Thanks Thanks x 1
  12. Eddieglmr8105
    Eddieglmr8105
    13 Nov 2018
    6
    Thanks Received:
    Country:
    Gas guru thank you! That had come loose all fixed that's fantastic.
  13. DIYnot Local
    3 Sep 2019
    Country:
Loading...
Share This Page
