Hi, this baxi 80 eco does not start at all in both hw & ch the only part running is the pump, Hi Limit stat ok no 240v at the fan, checked all the cables for continuity ok, pcb!!
by limit stat you mean over heat stat on left hand side have you bridged it out. As dave said make sure microswitch on TOP of divertor is being activated
