This is my first query having tried a local plumber who failed to turn up or let me know he wasn't able to see me despite me spending all day waiting for him and ringing him to check if he would still be coming 3 times. Gripe over.
My boiler works OK when the weather is not too cold with the operating pressure between 1 and 2.5 bar. Early last year with the snow on the ground it stopped and my daughter's boyfriend who is himself a plumber (they have now split up more the pity) re-pressurized the system as the pressure gauge was reading zero. This seemed to do the trick and it worked all throughout the year and including the freezing cold weather over last November, December and January. However this week after a few nights with the temperature dropping below freezing again I woke up in the early hours of the morning to find the boiler had turned itself off. There was no pressure reading on the gauge plus the pump/low pressure red warning light together with the lower green tap light were flashing. I turned on all the radiators and re-pressurized the system as shown previously. The boiler started up automatically and continued to work normally however over about an hour the pressure gradually dropped and the boiler cut out again with the two flashing lights back on.
In order to keep the pressure up I left the inlet taps on slightly watching to make sure the system pressure stayed below 3 bar then went back to sleep. That same morning I phoned the aforementioned plumber and turned off the inlet tap.
Having had no response from the plumber that evening I checked the pressure, which was holding steady, so decided to leave well alone. Last night and today the boiler has been working perfectly operating within the normal operating range 1 - 2.5 bar.
The overflow pipe does not run to a bent copper pipe on the wall, instead it is plumbed into the toilet drain/vent pipe, at least I think that is what it is so I can't tell if there has been any leaks to the outside from the boiler.
All the radiators work normally, no cold spots and all bled with no air in them. There appears to be no leaks anywhere around the house, inside or out.
I am of the opinion now that when we have sub zero temperatures for some reason something causes the pressure to drop and the boiler cuts off - but if so what?
Any help or advice would be most appreciated.
Thanks.
Thanks.
