Baxi duo-tec (new style)
15 Apr 2005
Yorkshire
I keep getting a recurring fault, Error 09 - gas valve connection (IIRC).
Anyone seen this? I had a heateam engineer round, who told me it is a known fault where the circuit board is confused by varying incoming voltages, and they are working on a fix for it. They will be in touch with me once a fix is released.
The engineer only popped round to make sure I know how to reset it. "Turn it off and back on again". The classic. Anyone seen this issue before?
2 YEAR G`TEE minimum so call heat team straight back out he has fobbed you off
I have found that by bending the two end pins out on the gas valve this makes the connection to the gas valve lead better and fixes this problem although I don't recommend you personally doing this but suggest it to the heateam engineer who comes back out to fix it for you as the last poster put it is still under warranty and should therefore be fixed!
