Hi any help appreciated.
I have A Baxi Bermuda, ive looked on the site and mine looks like the C5 but i have the on off dial on the side of the fire not the top.
heating goes on and heats up lovely, then here a click sounds like 2 copper tubes being tapped together.
Then a air bubble sound "very" noisey (Whale indegestion noisey.)
Then cold water shoots out external over flow.
Recent work 2 towel radiators fitted, but the air gurgles where there prior but not so worrying and not so much over flow.
I' ve just had a water meter fitted so not the best thing to happen right now.
The set up
all pipes lead to the copper water tank.
top of the tank 2 pipes attached both with the usuall flat blade closing valves.
On the wall i have a large red thing which i think must be the pump it gets very hot.
below it directly is a copper type of shut off valve that would need the red cock stop handle not a flat blade and there is alos one of these directly underneath the red thing, i asume to isolate pump to replace.
Further across from this there is a pipe that goes up but goes no where and has a large copper cirlcular section on top of it, from watching programmes i think this to be the thermostate.
there is also some other release joint down in the lounge, that comes from out the chimney stack so definately attaches beind the fire.
Any ideas any one, I'm happy to try anything.
thanks
The set up
thanks
