baxi he 80 leaking water
28 Jun 2010
Lincolnshire
the leak is coming from the 3 way valve assembly i have heard the is a service kit for this but cannot find any part numbers can any one help
also is it an easy job to take on yourself
I have come across this problem with this boiler plenty of times. Invariably it is caused by poor install and poor maintenance. Best to get a repair specialist to check the whole system.
If you don't remove the cause of the problem, it will be back before you know it.
I went to one of these leaking from just about every orifice. It turned out the schrader valve had failed in the pressure vessel and everything was being pressured to 3 bar. I new valve from local garage (£1) repressurised to 1 bar, tightened a few things. No more leaks.
Alfredo
Hi all,
Sounds like the DHW gland nut is passing water (common fault) unless the main part of the DV is weeping from a perished o ring. A picture is helpful, or an exact description of where the water is leaking out :wink: Get an RGI to have a look at it, simple fix....
hi here are a few pics its leaking from where the valve meets the swith you can see the water marks on the parts
and one from underneath
thanks
