Greetings all.
I have a Baxi Luna HT 380 (Condensing Gas Fired Wall Mounted Combination Boiler), approximately 15 years old. It has been serviced every two years over the course of it's life and has operated mostly trouble free during that time. I live in upstate New York and the winters here get pretty cold, so it runs alot during cold weather.
About a month ago I noticed a rather loud “Squealing” noise coming from the boiler when drawing domestic hot water. It does not make the noise when only floor heat is running.
My service technician came and replaced the electrodes and did an acid flush on the heat exchanger.
In any event it seemed to be fine for a couple days, now the squealing noise has returned, and more concerning is that the unit is now shutting down occasionally (maybe2 -3 times per day) and showing the E133 error code.
My propane supplier came today and did a pressure check on the gas line, and it is OK.
I asked the boiler technician whether one of the new electrodes that he installed could've been defective, and he said not.
I would appreciate any thoughts as to what the problem maybe and how to correct it.
Thanks in advance.
Thanks in advance.
