baxi platinum 28HE Combi Boiler
15 Dec 2006
Durham
Morning
I have a baxi platinum 28 HE combi boiler and have noticed the radiators are hot despite not having the central heating on for months.. we have warm showers etc but deffo not had the heating on..
It would seem something is allowing hot water through the system maybe a valve open
Can an expert please advise what the problem could/is likely to be
Regards
Stephen
15 Dec 2006
Durham
thanks Mick, can that be repaired or is it a case of a new part ?
25 Jun 2008
Yorkshire
Remove the motorised valve head and run the hot tap making sure the pin comes fully out. But as mentioned possibly divertor sticking/passing. Drain the water and remove the cartridge and replace with new cartridge.
Nath
15 Dec 2006
Durham
ive unplugged from the motor.. to remove the motor is it as simple as removing the retaining clip and does the motor then come away from the pipework ?
Is it the motor that is replaced or the actual valve ?
