BAXI SOLO 2 50 PILOT KEEPS GOING OUT
30 Oct 2006
Merseyside
the pilot is fine until the burner kicks in then more often than not the pilot goes out virtually straight away.if you look through the veiwer the pilot seems to go out from the back to the tip but sometimes it will stay on and be fine.
any help please.
no thats not the reason
as chris says get some one to service it properly
THNXS LADS
but it seems like the pilot is being blown out from the tip of the assembly as you can still see the tip alight.is there any way it could be a draft blowing on it or something from the burner.
sorry if this sounds daft
cheers
walto90 said:
THNXS LADS
cheers
again GET IT SERVICED PROPERLY
the pilot light assemply is partially blocked and needs cleaning
Baxi solo 2. Pilot light right hand sidehalf way back ? , held in a housing that can be a pain to get out. Once main burner comes on it pulls flame away as you describe caused by partial blockage and pilot needs coming right out for cleaning not just blown at
